airplane hold downs for the field ?
A flat board about 8-10 in. wide with two large sized dowels drilled in at an angle to hook the tail in and a hole in other end to stake it down. We use work stiations[tables] and I just drill two holes into the table at an angle to stick the dowels into, hook the tail into the dowels and it's not going anywhere. start your engine, set it on the ground and go flying.
