RCU Forums - View Single Post - Tail heavy Twist
Old 08-22-2004 | 02:40 PM
LuckyArmpit's Avatar
LuckyArmpit
Default RE: Tail heavy Twist
Wow.....I have 1200 mah battery up against the fuel tank. You know the fuel tank area is rather large. I have the tank surrounded by foam. I also put in a 4.2 oz metal plate in with the fuel tank. I then drilled 2 holes in the wood up front (the furthest you can go!!!) and put on a bolt with lock wash on each side. This comes out to a little of 6 oz. The plane with no fuel seems to balance at roughly 4 3/8 or so. If I take out the bolts, it will balance at just about the 5 inch mark. Hmmmm...depending on how this Evo .46 flies it, I may have to
go after a larger motor thus giving me some extra weight in front and more power. Maiden voyage in about 2 hours. I've set the throws
at 50% except rudder. I will try it there and make adjustments.
Dave...
