Tiger Shark Engine's (ANYONE HAVE ONE )?
Have been trying for some time now to get this new .75 started.
Will burn off the primer i give it but just doesn't have enough to pull the fuel from tank. Have tried everything.
Have tightened every screw till it won't turn anymore. This engine is a ABC eng. it has a hard spot at the top of compression turn. Suppose to be this way and will wear in .
can hear a leak somewhere when I flip the prop by hand to prime eng. Sometimes I see fuel moving up to the carb and others I don't. Can't find leak . Just hear it at times like a hiss for a moment .
I have a fueling probe I use and have dis-connected it and ran straight plumbing from fill to carb and overflow to muffler, still cant get the vacuum needed.
ANYONE HAVE ONE OF THESE ??
Tony
