RCU Forums - View Single Post - Errors in Seagull Spacewalker II manual
Old 08-23-2004 | 09:24 AM
CrashBurn69
Default RE: Errors in Seagull Spacewalker II manual
A word to the wise on the throws. If you have trainer experiance, dont use the low settings. They are so low, that if you get in trouble there will not be enough to get out of trouble. Even on high throws its pretty mild, compaired to others. The CG located at the end of the sheeting, it still feels a little tail heavy. But I am wanting to get a CG machine to get a little more accurate.
