Question is my engine the problem? rappy 30 OS32
First I want to THANK everyone who has responded to my Power problem . so thanks this much(!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!).
now back to work guys to answer some earlier posts yes I have checked all of the the fuel lines and no cracks or problems found and I also have an in line fuel filter that is not plugged and have found no contamination in filter or fuel. also I have tried to richen the fuel mixture to the point where the engine starts to sputter and then leaning engine 1 click at a time to try to find some power. the needle valve seems to give the most power around 11/4 to 11/3 turns I have tried many different settings and still can not get any power out of engine. With the head on there is some "tightness" near TDC but I don't know How Much should be there. I can turn the motor over with just the fan Pretty easy. I am wondering if anyone has "burnt up" an OS 32 abc on as little fuel as this engine has through it totaling 7 gallons ?
