RE: Help!
could be too rich on the bottom end. Lean out the bottom end a bit. your temps seem kinda low. I wouldnt run a standard piston designed motor at 190 degrees- no matter if its making power its putting extra cold wear on those internal bits. A tapered piston design yes I would run at 180-210. Be more spefic as to what motor you have.
