RE: upgraded funfactor
i have the same hopups on my rally, except for the roll bar and alloy arms. i have also fitted a OS18 cvrx, this engine uses the original engine mounts, you just need to space the pinions out slightly. also fit some xtra bearing in each hub, the ones u use for the diff will fit on the shoulder of the stub axle and make the wheels much more secure.
hope that helps
