Sig Rascal - Carb setup
what about setting up your idle and cutoff settings? Do you use a computer radio? did you bother with idle up or throttle cut? I figuered out the open / close by blowing into the fuel inlet and working the arm - I'm trying to determine full throttle and closed settings (without servo bind) and idle/cutoff position????
