Good questions.
First, I usually break a new sequence into 3 figure chunks to memorize them.
SCAT Basic I would memorize like this
From Inverted, pull to 45 downline, center 1/2 roll, pull to exit positive
Humpty Bump, Pull Vertical, pull 1/2 loop, center 1/2 roll on downline, exit positive
Full Roll on Center
Then memorize the next 3 and then the final 4.
Remember, at a contest you will have a caller, but for practice you need to memorize them.
I can usually get a new seqeunce into my head in less than an hour doing the 3 figure chunks.
Also, go here:
http://www.scaleaerobatics.org/sequences.html
Download the Aresti Made Simple and Aresti Explained articles. VERY helpful for learning Aresti.
I "dry fly" at home sometimes. Sit there with your TX and imagine you are flying the sequence. Move the sticks as you "fly".
Otherwise, burn gas!!
Later.
