Go Back  RCU Forums > RC Airplanes > IMAC
 How to Memorize Sequences? >
IMAC Discuss IMAC style aerobatics in here
Old 08-27-2004 | 10:15 AM
GoeKeli's Avatar
My Feedback: (18)
Default How to Memorize Sequences?
Hi, I have not been trying to fly imac for too long. I started in may and went to a half a contest. The imac basic is pretty easy for me and with the help of a friend I got it memorized and am able to practice on my own. I really really want to get better and learn more sequences. The SCAT basic is my next. I have a hard time doing this alone. The stick models help with this? I made one from a small model. Does anyone tape a cheat sheet on their antenna? I picked out a few manuvers from the sequence and got them ok. Also, how does one practice when you can't get to the field? (read work!~).
Joe !~)
Old 08-27-2004 | 04:20 PM
Silent-AV8R's Avatar
Default RE: How to Memorize Sequences?
Good questions.
First, I usually break a new sequence into 3 figure chunks to memorize them.
SCAT Basic I would memorize like this
From Inverted, pull to 45 downline, center 1/2 roll, pull to exit positive
Humpty Bump, Pull Vertical, pull 1/2 loop, center 1/2 roll on downline, exit positive
Full Roll on Center
Then memorize the next 3 and then the final 4.
Remember, at a contest you will have a caller, but for practice you need to memorize them.
I can usually get a new seqeunce into my head in less than an hour doing the 3 figure chunks.
Also, go here: http://www.scaleaerobatics.org/sequences.html
Download the Aresti Made Simple and Aresti Explained articles. VERY helpful for learning Aresti.
I "dry fly" at home sometimes. Sit there with your TX and imagine you are flying the sequence. Move the sticks as you "fly".
Otherwise, burn gas!!
Later.
Old 08-27-2004 | 07:27 PM
GoeKeli's Avatar
My Feedback: (18)
Thank Bill! I do read Barrys article and basically understand. THat sounds like a very good way to memorize squences. I will get on it. I'll come out and watch this weekend and ask if I can help out. The IMAC basic is pretty easy for me to rememer. Just a lot of flying back and forth. The thing I guess feels different about the SCAT basic is that it has many center figures and that adds another dimention and it seems the next figure comes up a lot quicker. I'll try what you have suggested!~)
Joe
Old 08-28-2004 | 10:30 PM
Don Szczur's Avatar
I'm going through this myself for Unlimited practice. Not only does it help with unknowns, it also allows you to concentrate on overall flight presentation, let alone avoidance of zeros!
It really helps me if I talk it through with someone (whether they care or not is another story). My daughter or son work well (as long as they don't talk back too much). Then you can always talk to yourself.
Ok, there is a spin early on, so, ok enter the box from the left. Wind is probably over the right shoulder.
Pull up positive snap, push level.
One turn spin
three roll circle, ok, lets double check this one...
Ok, I'm back. I got the call sheet from the car. The battery is charging (otherwise I'd be flying). I left the back door open to keep the plane from overheating as I waited for my wife to come home. Now she is gone again and I'm stranded... til the battery charges.
Now, open up the book. Ok, three rolls outside. Now being inverted Want to push the rudder to the left, (don't worry about right or left, just push the rudder stick the same direction the plane is going (to the left)).
Now, lets start over,
Enter box from left, pull vertical, positive snap, lets do a positive snap to the left (that takes the plane away to help with positioning). Push level. 1 turn spin, exit inverted, ok push the rudder to the left and ailerons to the left to start the three roll circle to the outside.
Humpty bump, 8 point up, neg snap down.
Ok, from the beginning. Pull vertical snap left (out) exit upright, one turn spin, three roller to the outside (push sticks both to the left to start). Exit inverted push straight up 8 point roll (lets go left with the torque on the engine) half inside loop neg snap down, exit upright. Next is roll, opposite 3 of 2, opposite 6 of 4 exit up. OK think about this one. Roll right, left 3 of 2. Right six of 4.. Close the eyes. Ok here it comes from the left. There is the roll, there is the 3 of 2, there is the 6 of 4. This is a tough one. One more time… there is the roll, there is the 6 of 4.
Ok, from the beginning, Pull vertical snap out, exit up, spin, three rollers outside, push up, 8 point roll, humpty, neg snap down, exit up, roll, opposite 3 of 2, opposite 6 of 4. Next. Hammerhead, pos snap up, 5 of 5 down. Ok want to go out. Roll is in (towards the flight line). OK close eyes. Pull vertical pos snap (again to the left) Hammerhead, left 5 of 4 down.
OK from the beginning, pull vertical, pos snap left, exit up, 1 turn spin, three roller left rudder, then left aileron. Exit inverted. Push, 8 point up, half inside loop, neg snap down (lets do it to the right, that will take me out). Tough one. Roll, keep it axial, left 3 of 2, right 6 of 4 exit up. Pull up again pos snap to the left, hammer to the right. Left (to me) one, two, three, four, five. Push out. OK backup, pull vertical, wait , wait, wait, now do the pos snap to the left, put in an equal line, hold some left rudder to keep it from weather vaning (I think the wind is coming from the right shoulder). Now we have lots of time to come down on the 5 of 4. Exit inverted across box. Ok what’s next. Another tough one. Tailslide, 1 1/4 pos snap down. Let’s see, tail slide, there it is. Want to snap the direction we are going. That would be right.
From the start, pull, pos snap up, 1 turn spin, three roller outside (right rudder, aileron), push humpty 8 pt up, neg snap down. Get ready. Roll, opposite 3 of 2. Opposite 6 of 4. Pull wait… pos snap hammer, left 5 of 4 down, push line it up. There it is, tailslide. Right 1 ¼ pos snap down. Punch the up elevator to start, and end with down elevator, to keep the heading from going off (remember the pos snap will be with the wind…) Next…Vertical 8. Nice position (out) make the loops nice and round. Next. Half of a diamond loop. Simple pull 45, pull 90, exit inverted. Next Avalanche from top. OK 1/½ pos snaps at bottom. Lets do the pos snap out. Exit with down elevator. Keep a lot on concentration on the wings exiting. it’s a tough maneuver.
From the start. Pos snap up, exit up, spin , 3 rollers (Right, right) push 8 point roll left, half inside loop, neg snap down. Roll, opp 3 of 2, opp 6 of 4 (Close eyes, one two, three, four, five, six). Pull vertical, wait, snap out pos. Hammer, left 5 of 4 down, push neg cross box. Push, tailslide (right rudder will keep it from weather vaning before the slide) Pos 1 ¼ snap down. Vertical 8, half diamond, pull down into an avalanche, 1 ½ pos at the bottom, exit up. Next. Push vertical down, 1 ¼ pos snap exit cross. Lets look ahead. Pull vertical 1 ¼ neg snaps up exit inverted. Square loop from the top. Now, lets take that cross box out 1 ¼ pos snap to the left.
From the start. Vertical snap, spin, three roller (right right), 8 point left up, half inside, neg snap down, roll, 3 of 2 opposite, 6 of 4 opposite. Pull, snap up, hammer , left 5 of 4 down, tail slide, right 1 ¼ pos down., vertical 8, half diamond, avalanche 1 ½ snaps at bottom, exit up, push down left 1 ¼ pos snaps, cross box, pull left 1 ¼ neg snaps up square loop…. Now lets look at the sheet again. Square loop on the corner. Pos snap on 1st 45 degree, 4 pt roll on third 45 degree. Exit inverted exit box.
Stand up, stretch,….get a drink of water. OK from the start. Talk it through with your wife, dog, lampshade, caller, whatever. … Judges, I’ll be entering from the left. Take off. Entering the box. OK pull vertical, pos snap up, one positive spin, exit inverted. OK keep it relatively close because we have a circle coming up. OK circle three rolls to the outside. There is the left rudder to start. There is the left aileron. There is the down elevator, there is the right rudder. Firs cardinal point. There is the down elevator, there is the left rudder, there is the down elevator, there is the right rudder, upright on the far side. There is the up elevator, there is the right rudder, there is the down elevator….etc. Ok, push vertical, 8 point to the left. One, two, three, four, five, six, seven ,eight. Half inside loop, neg snap down. Roll, opposite 3 of 2, opposite 6 of 4, exit up. Pull up, wait. Pos snap out, hammerhead, left 5 of 4 down, exit cross box inverted. Push vertical, tailslide. Come on baby, come on baby. There’s the slide. Pos snap 1/¼ to the right. OK Remember go out pretty far for that hammer head. Take it out to the edge of the box. Because we want enough room to get a horizontal line in before we do the vertical 8. OK, Vertical 8, eat in some to wind correct. Half diamond loop. Avalanche, 1 ½ pos snaps, exit up. Pull 1 ¼ pos snaps left, exit up cross box. Pull, 1 ¼ neg snaps left, exit inverted. Diamond loop. Pos snap left on first leg. 4 point on third leg. Exit inverted. Sequence complete. Congratulations. You just learned the TOC Unknown # 5 from the 1998 TOC. Thanks for bearing with me the last 30 minutes. Now its time to go out to the field to fly it.
See You,
Don Szczur
Old 08-28-2004 | 10:59 PM
Don Szczur's Avatar
How did it go? Got to the field. Wind was blowing from the right at about 12 mph. It was gusting hard. Only 4 guys out there and three of them were in no hurry to fly in the wind. Great! Thats my cue.
Takeoff, enter box. Vertical snap went well. 9 or 10. One turn spin. Oh no! I do about 1 1/8 (stopping myself from almost doing two). One spin goes really fast. OK circle. Wind pushing it past and pretty far out. No problem punch the throttle. OK back to center. Not too bad. 8 point up looks good, half loop good, neg snap down, looks great. Now roll, opposite 3 of 2, opposite 6 of 4, looks really great! Only problem is I'm out at 150 to 160 meters. Should I change and come in? No, I push it in on the radius. Not the right move. wings were off on the pull up. OK, pos snap. OK hammer head. Sloppy. Five of four down. Ok Tailslide. Push vertical, set up. Boy that wind is drifting hard. It backs down and starts to fall to one side. I save it and its through. Now the plane is drifting pretty hard, line at about 15 degrees off and try and do a pos 1 1/4 snap with the wind. Looks pretty ugly. OK Done. Vertical 8 loods great. Half diamond looks perfect. Avalance. Looks good but pushed the left side too much (wind drift). Full throttle on the back side to exit upright. Looks like a good exit. Push vertical down left 1 1/4 pos snap. Just OK. Exit upright cross box. Pull vertical 1 1/4 negative snap. Looks pretty good. Square loop on corner with pos snap. I decide to do the pos to the right, snapping in. Good decision. It helped wind correct. Second leg fine, third leg 4 point roll looks good maneuver complete. Sequence complete. I do a half roll, then another half roll then roll again before doing a half loop. Bad move. Should have just done a half loop with no rolls to exit..
After action report. The tailslide was the toughest part. I did it twice more before it came down just right, but the snap was still causing the line to be off 15 degrees. Just a tough one. Another thing that got me was the one turn spin. It was over before I was ready for it to really start. What else. Yes, got to work on rolling circles upright and inverted. Particulary in the wind. Biggest surprise. The rolling maneuver (roll, opposite 3 of 2, opposite 6 of 4) was one of the best presented and was easy to do it.
More you do it (memorize sequences and fly them) the easier they get.
Well. Time to pull out a different unknown and get ready to go through the same drill tomorrow...
See you,
Don
Old 08-29-2004 | 01:02 AM
GoeKeli's Avatar
My Feedback: (18)
Don! That was awesome! Do you have the aresti for this sequence? I'd love to learn just a few of those figures! It was a long read but I get where you are going with you method of memorization.
Joe
Old 08-29-2004 | 09:23 PM
Don Szczur's Avatar
http://www.desertaircraft.com/articl...98TOCSequences
Unknown 5, Saturday PM.
Don
P.S. check out their line of products (Desert Aircraft). They also have unknowns from 1999, 2000, 2002.
Old 08-30-2004 | 12:09 AM
GoeKeli's Avatar
My Feedback: (18)
Thanks Don! I have never seen those articles on the DA site. I love their products and have a few of their engines. Thanks again.
JOe
Old 08-31-2004 | 10:35 AM
My Feedback: (10)
Don,
You are a real gentleman!
Still flying at NVRC?
Old 08-31-2004 | 08:40 PM
Dean Bird's Avatar
My Feedback: (39)
Joe,
I'm expecting to see you and the new plane flying at the JR-SCAT Series contest in Coachella on October 8th & 9th. I think registration opens on September 4th.
The Basic class if full of great pilots and the contest always has lots of helpful, experienced pilots that will call for you and anwer questions before and after your flights.
See you there!!!
Dean Bird
2004 Sportsman Class Champion
JR-SCAT Scale Aerobatics Series
Old 08-31-2004 | 11:43 PM
GoeKeli's Avatar
My Feedback: (18)
Thanks Dean, I'm really gonna try and make that., THe 2.3 is really fun, I flew today and got it wrung out. I stopped by the SCAT contest last sunday and saw some of the guys. I took some photos if you want to take a look,
http://homepage.mac.com/joekelley/PhotoAlbum63.html
Joe
