RCU Forums - View Single Post - Kawasaki experts --- help !
Old 08-28-2004 | 11:03 AM
ZAGNUT's Avatar
ZAGNUT
Default RE: Kawasaki experts --- help !
if you want simple you can use a stock G-23 hub and prop nut on that shaft. might have to flip the crank around though.
also if that clutch housing is removable it'll save quite a bit of weight and you'll still have four studs to screw the mount plate to. or better yet just put four screws through the firewall
dave
