RCU Forums - View Single Post - 1/8 scale buggy!!!
Old 06-26-2003 | 12:13 AM
DSA.308's Avatar
DSA.308
Default 1/8 scale buggy!!!
No, the flywheel doesnt touch the block at all, the clutch bell comes out farther than the end of the crank when using the fioroni flywheel/clutch! So when you tighten the last cap screw, rather than tightening against the end of the crank like it should, it locks the whole assembly up because the crank is 3-4MM too short.
