RCU Forums - View Single Post - Start box problems
Old 08-29-2004 | 07:23 AM
Woketman
Default RE: Start box problems
P.S. The bad solder joint was a cold soldered joint and was intermittent. We could wiggle the wire where it went into the box and get the display to change. Does yours do that? Of course, it could be an intermittent connection on either end, his just happened to be in the start box. Hope it helps.
