RE: Problem with Hobby Town USA
Geistware, is it the KSJ unit you are talking about? If so run the little set screw in while turning the handle. When it locks, back off just a little. Good unit after you get it adjusted. If it can't be adjusted I woud say it is bad out of the box. Several folks around here using them and they are working great. Has turned into my favorite hand crank unit.
Ed M.
