RE: AFP On Order
AFP "Immediate Dislikes" : There were some things I did not like initially.
1. Program interface - already mentioned having to go back to main screen to swap planes. Inability to switch between basic and advanced editing for a joystick is another example.
2. Wind - no parameter for a variable direction
3. Dual Rates - no apparent way to set up dual rates with a joystick controller.
4. Editing aircraft/scenery - This is not as easy from within AFP as in G2. For example, want to add a windsock by the runway or change the tail gear on the Sukhoi to a wheel. I could not do this from withing AFP. Understand there are external editors to create planes unlike G2.
1. I really wouldent call it complicated and going back to the mainscreen you just press escape?
2. Yes there is
3. Joystick? well in all fairness your supposed to be using a RC transmitter. How do you use a joystick? they only way to do that is a crack?
4.True
