RE: AFP On Order
Thanks for the reply.
How do you set variable direction for wind? I see how to change the direction (i.e. 30 degrees vs. 100 degrees), but how do you set it to 30 degrees, with a 10 degree variance (i.e. it varies from 20-40 degrees)?
I am using a RFG2 controller (i.e. joystick on the AFP menu) ... certainly not a crack.
Carl
