ORIGINAL: q8murder
im a newb with engins i wanted to know must the carb be fully closed when idle or should i adjust it to open a bit more on idle?????? and should i make the carb tite (hard to open and close the carb) ????????
it should be open about .5mm, BUT its hard to adjust based on sight,
you should turn your engine on, and adjust it off the ground (on a starter box) and just see if the car moves by itself at idle. and also see it the car dies when you brake.
