Yes, that is the unit.
My problem is that it desolves the plastic (milky white fluid mixed in my fuel).
It also leaks like crazy and takes a million cranks to fill a 32oz tank.
I will go back to using gravity!
ORIGINAL: bentgear
Geistware, is it the KSJ unit you are talking about? If so run the little set screw in while turning the handle. When it locks, back off just a little. Good unit after you get it adjusted. If it can't be adjusted I woud say it is bad out of the box. Several folks around here using them and they are working great. Has turned into my favorite hand crank unit.
Ed M.
