Yes, that is the unit.
My problem is that it desolves the plastic (milky white fluid mixed in my fuel).
It also leaks like crazy and takes a million cranks to fill a 32oz tank.
I will go back to using gravity!
I know of about 10 guys using them and I have two, one for glo and one for gas, never seen that problem before - but i will be watching for it. I assume you did change out the tubing before using it for gas, stupid to ask I know, but........
Just as info: To get the pumping speed up there is a small hole in the back with a hidden screw that takes a small allen wrench. If you tighten the screw I am not sure if it tightens the gear mesh or causes a side plate to close up but the volume goes up, if it gets hard to turn you have gone too far. The speed that these units pump at was what attacted me to them to start with.
Ed M.
