RE: DA50 Balance in Edge - pull pull elevator?
I don't know why you would have to do that! I have a DA 50 in my Edge, and with the flight pack attached to the front of the wing tube, I'm just ahead of 5 inches for the CG. I am using pull pull for the rudder, and the throttle and choke servos are mounted in the radio tray just ahead of the rudder servo. I will admit to using a fairly heavy prop, a Biela 22X8, but the balance is not a problem. Have you tried balancing yours or are you just hearing of problems and thinking you might have a problem?
Jim
