RCU Forums - View Single Post - 3 out of 3 with broken front diff case!
Old 09-02-2004 | 04:30 AM
theerm
Default RE: 3 out of 3 with broken front diff case!
Some thing i noticed with my lst, With the brakes on , try and turn the wheels. you can see the the Main chassis Plate flex up and down big time. where the diff case retainer grabs the chassis. if this is what is causing the diffs to crack, i can't see aluminum fixing the problem. the main chassis plate will still need Better support or strengthening. see what you think
