RE: DA50 Balance in Edge - pull pull elevator?
Pretty much. I'm not in favor of putting batteries up front either. Sure, some people get away with it, but it's a matter of "headroom". You might get a decent range check, but it may be that just a little extra noise will put you over the limit, and then you're in REAL trouble. I've always felt it's better to be safe than sorry. I've even gone as far as putting weight up front to avoid having the batteries too close to the ignition. A heavier spinner or a lighter tail wheel will make an INCREDIBLE difference in CG.
Good luck
Jim
