Fox .45 disassembly
I need a little help disassembling an older Fox .45 engine. I have removed the large pressure plate on the rear and removed the sleeve. My problem is removing the piston and connecting rod. They don't slide off the end of the crank like most engines. I think the large pressure plate is for removing the wrist pin but it won't come out.
Can anyone help?
Jim
