Fox .45 disassembly
OH
I need a little help disassembling an older Fox .45 engine. I have removed the large pressure plate on the rear and removed the sleeve. My problem is removing the piston and connecting rod. They don't slide off the end of the crank like most engines. I think the large pressure plate is for removing the wrist pin but it won't come out.
Can anyone help?
Jim
Can anyone help?
Jim
As said before, with the sleeve out the rod should slide back far enough to come off the crankpin. However, even with the piston back against the case the rod may still have to slide back on the wristpin as well.
If it does not it could be that the rod is siezed/tight on the wristpin and will not move back far enough. If, If this is the case I have a couple of suggestions. Understand we are talking about desperate measures. Is it possible to get one of those small butane or propane torches with avery small flame and heat up the top end of the rod. Heat it, not melt it, a local heat on the rod only might just pop it loose. Or, maybe get a small piece of hardwood around the front of the rod to rest on and tap the wristpin/piston forward. Like I said we are getting desparate.
Just remember, that engine had to go together, therefore it must come apart.
Ed S
Ed S
isn't the high back door supposed to allow room for the piston and rod to move back off the crankpin??
Ed S
Fox was very inovative with reducing maufacturing costs, its my understanding the barn door backplate was a trick to reduce manufacturing costs. If the wristpin is stuck it could be due to congealed castor oil. If so heating it up may do the trick, or soaking it in fuel or denatured alcohol could also free it up.
A good fix here would be to take a 12 lb sledge hammer and smash the engine repeatedly. This will solve your problem. I had a Fox 40....emphasis on the word "HAD". It was the worst piece of junk engine ever. A new OS 46 AX would make a very nice addition to any modeler's collection......
ORIGINAL: Ramz-to-tha-z
Rather give the a few dozen medium taps with a two lb. ball peen.
If the engine is rendered into small bits, it cannot be used for fishing
sinkers !
MB.
