RE: thinkin about converting
Your radio will work just fine......4 channel. The LMH uses micro servos unless you upgrade to the metal frame conversion.......then you have a choice to what size servos you use. Gyro and engine should be it.....except for fuel, starter and glo starter.
Mark
