thinkin about converting
right now I have a MS composit hornet microelectric helicopter, an i really want to upgrade to a larger heli, pref. one that uses glowfuel rather then electricity. The thing(s) that i really want to know about the 116 and/or the 117 are: does the 116/7 use micro servos, if so will i be able to gut my hornet and use the parts from it? will i have to upgrade the type of transmitter that i have? (the futaba skysport4 old i know but layoff!!![sm=wink.gif]) i suppose the real question i am asking is how much extra i will need to purchase in addtion to the model kit, the gyro, the engine and muffler?
thanks alot
thanks alot
Your radio will work just fine......4 channel. The LMH uses micro servos unless you upgrade to the metal frame conversion.......then you have a choice to what size servos you use. Gyro and engine should be it.....except for fuel, starter and glo starter.
Mark
Mark
