RE: BVM F-80 setup?
Hi Scott,
Thanks for your input.
The model is balanced as you describe above, so this should be ok.
The model was tested without flaps, and I was told on RCGroups.com today, that the control throw should be 10-15 degrees - and flaps as you describe.
Actually the flaps can go to almost 90 deg.
Cheers
