RCU Forums - View Single Post - One ground wire on Twin
Old 09-08-2004 | 07:53 PM
Geistware
My Feedback: (16)
Default RE: One ground wire on Twin
Thanks, after several people recommending this, I guess I will try it!
ORIGINAL: RCIGN1
Nothing I can think of, or you can connect the ground wire to a drilled and tapped hole in the top fin of the cylinder..As long as it doesn't disconnect somehow....If you use a lug on the end of the wire it's better to crimp it, a soldered lug sometimes breaks at the joint...
