RCU Forums - View Single Post - "Shear Web" Question?
Old 09-09-2004 | 03:03 PM
MikeMc's Avatar
MikeMc
Default RE: "Shear Web" Question?
When the spar is under compression (before the wing bend actually happens) it can go in any direction. That includes away from the other spar. So the web can be under compression or tension hence glueing the web to the front or back is better than in the center of the spars IMO. The key is when the spar is deforming from compression but before an actual bending or catastrophic failure of the wing occurs.
