RCU Forums - View Single Post - C.H.Ignition problem??
Old 09-10-2004 | 05:58 AM
Geistware
My Feedback: (16)
Default RE: C.H.Ignition problem??
Do you have a screw driver with a magnet built in?
You can use an old speak or anything with a magnet but it does have to be fairly strong.
If you loose the ground on your ignition you will fry the sensor really quick!
If your sensor is dead, did you loose your ground, or the ground wire come off?
ORIGINAL: Bass1
Awesome!
