RE: re-cover super skybolt
I have found, by mistake, that if the covering leaves the color and glue behind, wipe down the balsa with brake cleaner and a clean rag. The brake cleaner will pull the glue and color off in no time. You can also use the brake cleaner to stick monacote down without heat. I have found it makes a good trim solvent.
Dru.
