RCU Forums - View Single Post - 15 cv-x hyper, difficult to turn over
Old 09-10-2004 | 03:14 PM
Bax
Default RE: 15 cv-x hyper, difficult to turn over
If you can't get the bit of wrench out of the socket bolt, you may be able to get a saw between the head and the case to cut the bolt. Just go in between the fins. You can sometimes get in there. If the bit of wrench isn't in the bolt, but the head of the bolt is damaged, you can drill it off quite easily.
