RE: BME Edge?
It's a great flying plane no doubt about it. Rock solid harriers, very clean walls and parachutes. Looks like waterfalls are pretty easy to do also. Even over 17lbs the Brison 3.2 was good power for 3D. As far as the wing area and weight are concerned, it doesn't mean much when the plane flys as good as it does. One issue I did notice was the fact that the plane pulled a good bit to the left on the uplines. I believe Bryant330L also put additional thrust along with the thrust built into the motor, it still pulled to the left. As far as the rudder authority, another friend of ours has a H9 80" cap, after flying it I believe the rudder authority is comparable, just something to get used too maybe?
I was kicking myself for not bringing digital camera and getting some pics and vids! Next time I won't forget it. I'll post them when I get it them.
