RE: Walker 3.2 vs DA 50,BME 50
Some of the new engines also have relocated the carb to the rear. Makes for a neater package to fit inside the cowl. Some of the new engines also use reed or rotary valve for intake timing. This can give a wider powerband with less fuel spitting out of the carb. The older piston port engines have symmetrical intake timing, which is a compromise.
