RCU Forums - View Single Post - Dave Patrick super cub
Old 09-12-2004 | 09:45 AM
  #217
Quick 1
Default RE: Dave Patrick super cub
ORIGINAL: Bud Faulkner
Thanks builder Jim, I'm mounting the engine the same way I did my G38 in my BUSA cub....T nuts from the inside of the box and 1/4-20 bolts thru from the inside with threads on the outside and bolt the engine with nylon insert aircraft nuts. Pulls against the T nuts. When I first tried to mount it I couldn't figure why when I lined up the center of the box with the center line of the firewall why it was not right, then I realized the box has to be offset due to the right thrust built into the firewall....with the offset this puts the center of the engine at the prop right on the center of the firewall duh! I e-mailed edr and Andy said the no hassle way to go if you don't like wiring is the way you went, I told him I didn't need the charger and he said they can ship without and just take the cost of the charger off. Aren't you about to get in the air with yours? The 16th right? Do we get a report that evening?
Very nice setup bud! Looks good! And yes I will try to post a thread that evening on how the flight's went and also I will post the finished aircraft pics aswell! Just a head's up on your model don't forget about throttle to cowl placement as we had to redo our entire setup on our throttle linkage. Because I missed the measurement by a 1/4 in and the cowl wouldn't line up. Jim had to go back and redo it. And I gave him a reason to harass me argh! (He ended up mounting the servo directly in line with the throttle arm)
