RCU Forums - View Single Post - Nobler bell crank failed
Old 09-12-2004 | 04:30 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Nobler bell crank failed
I Suspect WCB is talking about the Top Flight ARF Nobler and probably not Brodaks. WCB do not dispair about the dizzys. First off you were not flying and to follow someone else within the circle is far more disorienting than if you are the one flying. The pilot will tend to stand still and just rotate while you will be forced to run around a bit. This is nothing like flying the ship yourself. Be assured the dizzys will go away after a few flights when you are the one flying. The rewards of truly being connected with the aircraft in flight are great, stick with it, rebuild and reap the rewards that only fellow Ukies dudes will understand. [8D]
John
