RCU Forums - View Single Post - Walker 3.2 vs DA 50,BME 50
Old 09-12-2004 | 04:57 PM
ronk1
My Feedback: (25)
Default RE: Walker 3.2 vs DA 50,BME 50
I will go along with you on some of your points but a rear carb is a pain to get to. If you have a boxed in firewall (most large planes do) you need to remove the engine to do carb work[:'(]. As for "spitting" I've never had one do this. I do have two reed valve engines but they are twins. My three singles are piston port and run super. I must add though the single cylinder engines have the carb inside the cowl, this does make a big difference.
