RE: C.H.Ignition problem??
Ian, Thanks for the heads up on the solder issue. If the new sensor doesn't do the trick, I'll re check all connections. I did apply some heat shrink around the deans connectors when I installed it on the airplane. Maybe I overheated something with the heat gun.
