RCU Forums - View Single Post - ok im mad
Thread: ok im mad
Old 09-13-2004 | 05:42 AM
wover98's Avatar
wover98
Default RE: ok im mad
The CA on CLEAN wood is fine, will be stronger than ajoining balsa wood.
However, the epoxy will give you more working time to make sure all is
squared up well. Its a good thing it came off while on the ground, and not
while flying. Sounds like you had a week joint to begin with. (assuming that
it came off clean, not splintering the wood)
Hope this helps.
