RCU Forums - View Single Post - Servo linkage on ailerons
Old 09-13-2004 | 12:17 PM
Rodney
Default RE: Servo linkage on ailerons
It makes no difference where your servos are, inside or outside. What does matter is that you must have a seperate servo on each aileron to utilize them as both flaps and ailerons. How you mix is determined by the transmitter you use and mixes available on it.
