RCU Forums - View Single Post - Tail Heavy ARF's
Old 09-13-2004 | 03:49 PM
flycatch
My Feedback: (26)
Default RE: Tail Heavy ARF's
The answer to your question is that the placement of the main landing gear is in the wrong location. All trike landing gear aircraft
must have there main gear located aft of the CG. You problem is a direct result of having the main landing gear mounted directly on the CG.
My assumption is based upon the aircraf having a constant chord wing with the CG set at 27%.
