RCU Forums - View Single Post - FMS FPS problem
Thread: FMS FPS problem
Old 08-04-2002 | 02:41 AM
canesugarrules's Avatar
canesugarrules
Default FMS FPS problem
Mine does that every now and then. To make it faster, I truen the resolution down low, let it load, then turn it higher. There is also some other adjustment, 16 bit and 32 bit. Don't know what they are or what they do, but changing them usually helps. Usually I will get 50 FPS with a slow Dell. Good luck and I hope this helps.
