RE: global freestyle
Still pulls right..had to put only 4 clicks left trim though..not bad..the landing gear and prop made a huge difference in takeoff..im off the ground in 75-90 feet,much better then 200.. This was the first time i was able to put it through some moves..I turned a knife edge into an upwards corkscrew..not sure if that move has a name but it should..looked cool..only problem im having now is that my carburetor is sticking after getting hot..I changed it with my 46fx carb and it still does the same thing..I had this same engine (os 50sx) on a magic and it never done this..after cooling it still sticks so i have to take it apart and put it back together..works fine after that..strange..any way im happy with the performance and i will keep you posted on the carb problem..Thanks for all your guys help..later..
