RCU Forums - View Single Post - ceramic bearings ?
Old 09-14-2004 | 02:10 PM
  #34
ZAGNUT's Avatar
ZAGNUT
Default RE: ceramic bearings ?
ORIGINAL: downunder
One thing that hasn't been mentioned as far as clearances go (C3 or whatever) is that the bearings are fitted with an interference fit when cold (we all know you have to heat the crankcase to remove and fit them). This interference fit (the shrinkage of the crankcase as it cools) squeezes the outer race and reduces the free running clearance. Add to this a tightly fitted crankshaft in the inner race which expands it and the clearance gets even smaller. If you start with too little clearance in the bearing when free it's quite possible to end up with zero (or less) clearance with a cold engine.
i have mentioned this and the fact that in some cases you can even measure the reduction in clearance of the installed bearing...different thread though
dave
