RE: Starting the Dualist 2/40
Thanks Will. I hadn't thought about the extra takeoff problems that can arise with a twin. All my current planes are tail draggers but no twins. I also must have the MK II as the rudder is the same as the one on the left if your photo.
I will look into the Tower Hobbies gear as the Robarts may be a little too pricey up here in the Great White North.
I suppose to cure any clearance problems I could move the gear out one bay and make the legs longer. So long as the wing is strong enough. Did you fibreglass the entire plane? Is it required?
Thanks to all for your input.
