RCU Forums - View Single Post - CONFUSED!!!!!!
Old 09-14-2004 | 09:38 PM
KICKINDIRT
Default RE: CONFUSED!!!!!!
Also make sure the flywheel nut is tight or the slipper clutch is properly tightened. It sounds like the diff is stripped,because it will turn the wheels when lifted off the ground,but when you set it down nothing happens
