CONFUSED!!!!!!
i need help with my rc truck i was driving it and i jit a bump and let go of the gas and **** like that but when it landed it went for like a couple inches and it just stopped. it wont move. so i picked it up, and the tires turned again like nothing was wrong but when i set it on the ground it wouldn't move the tires only move when its off the ground. im thinking theres somthing wrong with the engine but i dont want to **** with it and mess it up more. sooo if u have any ideas about wat might be wrong. please tell me.
First, what kinda truck is it?
Second, put the truck on the ground and hold the spur gear in place with your finger. Push the truck backwards to see if it wants to try to move the gear under your finger. It should as long as nothing is wrong with the differential. Also, make sure the clutch bell spins freely and the gear mesh is correct. Sometimes a hard landing and loose engine screws can cause the engine to jam into the spur gear and lock the two gears together. Also, when you try to drive forwards, does it sound like the engine is straining or is it just free revving and nothing is moving, like it's in neutral or something.
FL
ORIGINAL: opeth
futaba i believe. and yeah it sounds like its just revving up its wierd. and i checked the gears and there not stripped im sure of it. and i cant checked wat u siad creyc b/c i dont have any batteries for my remote. so as soon as i can try that ill tell u. and every1 else the same.
HELL YEAH OPETH IS BADASS!!!!!!!!!
VA
Also make sure the flywheel nut is tight or the slipper clutch is properly tightened. It sounds like the diff is stripped,because it will turn the wheels when lifted off the ground,but when you set it down nothing happens
VA
ORIGINAL: KICKINDIRT
I know he says he doesn't see damage but remeber, the spur's edges will wear down, don't look for missing teeth...
hope that helps. lol
