Sledge 540 progress.
Jeff,
I used the wood supplied for the Shear webs (I-Beams) with the grain going vertical. Doing it this way, the pieces arent wide enough to fit completely inbetween the ribs. They are glued up against each rib on the inboard side. Same support as far as I could tell and a lot less work on cutting them to fit.
Wing is just about done. Need to build the hatch covers and do the cap strips. Then its on to the sticks!
