RE: Help: Programming 9C for DLG
Hi Mousson,
Sorry it has taken me so long, I have had this on my desk for a few days playing with it.
Forgive me if I have this wrong, but here is what I came up with. Try this out, if it doesn't work out for you, please please let me know.
I did three offset mixes first.
The first one:
Offset-Master
Elev-Slave
Link off
Switch F, down
rate-15%
The second one:
Offset-Master
Ail-Slave
Link off
Switch F, down
rate-100%
The third one
Offset-Master
Aux1-(or your second flap) slave
Link off
Switch F, down
rate-100%
Then I did two separate Linear mixes:
The first:
ARBK-Master
Aux1-Slave
Link off
Switch is STK-ARB
position Null
Posi-1 +100
Posi-2 -100
Posi-3 0
Posi-4 0
Posi-5 +100
Then I did the same linear mix again, but this time I made the slave Aileron.
I did this mix in Glider 2, you may have to adjust your percentages of course, but this give me up elevator and flaps with my F switch and when I move my throttle stick full down I get up flaps, slightly above full down throttle I get full down flaps and at full up throttle I get full up flaps again.
Let me know if this works for you.
Krysta
