RE: Why do drugs?
One very very important lesson i've learned is precision.. you dont need it. You can fly soooo much better if you dont try to control it within a certain tolerance. It is a demand you set onto yourself that's not required.
When I first started.. I wanted it dead still, like a statue. Now i let it sway and i control the sticks in a very "lazy way" If you're hovering nose in, and it wants to float away from you. Youre not obligated to IMMEDIATELY compensate for that movement. Let' it go and adjust when you're ready.
Another key is to set your dual rates at about 50% while you're learning. You will see a huge difference.
